want to switch to speed density
Old Jan 9, 2012 | 11:29 AM
Fastdriver1992's Avatar
Default want to switch to speed density
so my friend is wanting to switch to a speed density tune when he gets tuned by formato in spring but he has to drive the car 4 hours. is there any connector or harness or anything he needs? or is it just as simple as popping out the maf when he gets there?
Old Jan 9, 2012 | 12:18 PM
blackls1ta00's Avatar
im assuming your forced induction by your signature? so sd would benefit you.im sd on a 383 n/a and it sucks with climate change,so spring im going back to maf.jegs has a ceramic pipe piece that you use instead of the maf.but since your old school that might not help you, a pic of engine bay would help.
Old Jan 9, 2012 | 01:15 PM
its for my friend with a 383 ls procharged. he just wants to no if he can drive to to the tune with the maf then just pop it out and throw a hose where the maf would go
Old Jan 9, 2012 | 02:08 PM
keliente's Avatar
That works, you can even leave the MAF there if you wanted. SD is something that's set up in the tune it is not a physical part you add to the car. Whether or not he can drive it to the tuner depends on the rest of the mods...mainly...injectors.
