My p0134 story
USUALLY that code is present when there is not enough exhaust flow going thru the sensor itself or poor placement, wrong thickness of bung, ect....
It is saying that the o2 sensor is getting insufficient switching. When the ecm is swinging the fuel, it isnt registering on the sensor like it needs to be.
Poor gas mileage will result.
As for the fix, If it is stock manifolds, make sure you have the front one plugged in. In a scan tool, make sure it isnt just sitting at 450~mv.. If it is moving, then maybe try putting in a HOTTER higher quality o2 sensor into its place. ???
The cats that you put in are alot less restrictive, which is making it harder for the sensor to read correctly "less back pressure". putting in a new 02 sensor would probably fix it.
