98 pcm and trying to run a 4l80e
Old Jan 19, 2012 | 05:00 PM
TiGer85SS's Avatar
Default 98 pcm and trying to run a 4l80e
As the title says I'm trying to run a 4l80e, but I ve been told that the 98 pcm can't control it. So if I have to switch to a 99+
pcm what all has to be done? Another option is to run the 80 with a fmvb, but how does the vss, and converter lockup work without the pcm?
Old Jan 19, 2012 | 06:57 PM
flame's Avatar
You can run the 80E with the 60E tune and a couple relays to reverse the shift solenoid pattern. You can either buy this harness or build your own http://www.tunedbyfrost.com/products_dev1.htm
Old Jan 19, 2012 | 10:10 PM
TiGer85SS's Avatar
Ok thanks that will save me from having to run a standalone controller
Old Aug 19, 2013 | 05:02 AM
allan808's Avatar
I know this is old but did this work on the 98 pcm?
