LM2 issues
Old Jan 23, 2012 | 10:11 PM
evilbeef54's Avatar
Default LM2 issues
okay so i google searched it and there is a ton of unanswered threads on the innovate forums over the past year, so hopefully i can get some help over here...
I tried to update my LM2 WBO2 with the latest firmware on my laptop, it said that it programmed then it went to verify and gets to 90% and crashes and said "programming failed" this causes the LM2 to be stuck in the boot loader screen, it is now apparently bricked. I googled the issue and see multiple threads in the last year on the innovate forums, it seems that if you use a computer with anything newer than xp it causes this exact same issue, but if you call innovate they will blame you and make you pay to send it in and get it fixed, even though there are TONS of people with the issues.
Anyone have any solutions for this? I tried uninstalling logworks and putting the .exe in windows xp and win 2000 compatibility modes with no sucess, the unit will not get past the first screen...
hopefully someone here has found a fix for this
