96 S10 LSx swap, OBD2 data issue
I then checked the pcm plugs and pins 1 and 40 on both the red and blue connectors have continuity to ground, pins 20 and 57 have 12V all the time and pin 19 has 12V with the key on.
I put the pcm back in the truck and plug into the under dash obd 2 plug and it wont connect. If everything has power and ground like its supposed to be then it should connect. I'm ready to give up on this but not just yet.
The only thing i came across is that with the key off pin 19 has continuity to ground, and with it on it shows 12V. With the key off and the neg test lead on the alt. stud and the positive test lead on pin 19 is shows -12V, could this mean that pin 19 is shorted to ground, but is somehow still able to send 12V to the pcm with the key on but is causing the issue im having with not being able to link to the the pcm thru the obd2 plug??
Any ideas?
Peace
