Boost with Holley Dominator EFI
Old Mar 15, 2012 | 09:51 PM
that national's Avatar
Hmm, I still don't know, maybe if they offered s bigger discount on the coils I might go for it now but the coils are regularly $101 in summit. So $1 off per coil isn't enough.
Old Mar 15, 2012 | 10:12 PM
tonyturbo42's Avatar
Last time I looked they were $125 at Summit, and not to sound like a dick but if a hundred bucks difference is going to hold you up on buying a $2500 Engine Management system because it wont run stock coils, its not for you anyways. Go with a stock ECU if you are trying to save money you will be happier. The type of engine you need the Holley for will eat a hundred dollars in a couple fittings, or a flange or two without blinking.
