98 pcm on 02 ls1
Old Feb 12, 2012 | 01:52 PM
CWellman's Avatar
Default 98 pcm on 02 ls1
Can you put a 98 wiring harness an pcm on an 02 ls1?
Old Feb 12, 2012 | 02:21 PM
the_merv's Avatar
I dont see why not..as long as the PCM and Harness are the same.
Old Feb 12, 2012 | 02:41 PM
CWellman's Avatar
Ok. Cool
Old Feb 12, 2012 | 08:20 PM
MontecarloDrag's Avatar
That is a step backwards, but it can be done.
Old Feb 13, 2012 | 02:33 AM
01ssreda4's Avatar
Yes it can be done. You will need a 98 coolant temp sensor for the driver head. 98 is 3 wire, 99+ will have a two wire. Other then that it should be a direct plug in.
Old Feb 13, 2012 | 05:06 PM
ZexGX's Avatar
Agreed.
Agreed.
Old Feb 13, 2012 | 06:39 PM
the_merv's Avatar
GM 12551708..popular little sensor for only a couple years manufacture..lol
Old Mar 26, 2012 | 05:43 PM
blown99bergerssclone's Avatar
What about the fact that the 98 harness has 3 plugs and the 99 for the inside pass kick panel? What's the extra plug control? How to make it all work?
Old Apr 4, 2012 | 07:56 PM
ced98ss's Avatar
Thanks for the help guys...
