Help me out with stalling
Old Feb 21, 2012 | 08:33 PM
marthastewart's Avatar
Default Help me out with stalling
Can someone help me out with this stalling issue. Mods are in the sig. I dialed in the VE nicely. Then the MAF within 0-1. The RAF was then set. Turned on STFT's and though it runs good, all the stuff I dialed in went outta wack. Like I said, it runs good, WOT is nice with no knock, however.....
When ever coming to a stop it stalls. I have screwed with just about everything from the Throttle cracker, follower, Adaptive idle, Proportional, integral, and derivative. Nothing makes a difference. Can someone help me out here or at least point me in the right direction.
File Type: hpl
File Type: hpt
Old Feb 22, 2012 | 06:23 PM
BLK02WS6's Avatar
I don't have HPTuners anymore, so I can't look at your log... but, if you put the trims back on line and it throws fueling out of wack, you likely have exhaust leaks causing it to look like a lean condition and adding unneeded fuel...
