Couple of questions on swapping to a 99+ ecu.
Old Feb 27, 2012 | 08:21 PM
WeakSauce6's Avatar
Default Couple of questions on swapping to a 99+ ecu.
Picked up a set of gauges with almost the exact same mileage as my car has on it now and the ECU will be here by fri. I know I have a lot of work with re-pinning the harness, but was wondering if it will have to be tuned before it will work.
Old Feb 29, 2012 | 09:07 AM
WeakSauce6's Avatar
Anyone?
Old Feb 29, 2012 | 02:03 PM
wssxton's Avatar
what year car do you have and what kind? you dont need to change the gauge cluster if you are going to do a re pin. you will need it tuned before you can start unless the 99 ecu came out of a six speed car and your car is the same
Old Feb 29, 2012 | 11:25 PM
WeakSauce6's Avatar
Mine is a 98.
Old Mar 1, 2012 | 05:08 AM
wssxton's Avatar
all you need is the new pcm and do the repin. if you use a newer cluster you have to get a new harness. but if the new pcm came out of a car that is a m6 and your car is a m6 then you dont need a tune to start it.
