bad pcm symptoms??
Old Feb 28, 2012 | 08:32 AM
lt170chevelle's Avatar
Default bad pcm symptoms??
How likely is my pcm bad with a P0740 tcc cuircut problem and an injector fault code<I forget which code> I've heard could be likely for both and I've replaced tcc selenoid and injectors with neither helping. Just want to know if these are pretty common bad pcm symptoms.this is a 2000 pcm if it matters.
Old Feb 28, 2012 | 09:17 AM
Old Geezer's Avatar
P0145 is a O2 sensor code...The o2 sensor code could be tied into inj code[s]...If you knew which one, someone mite have an answer.
Scan and data log it... Post the log[s].
Old Feb 28, 2012 | 07:27 PM
Sorry its not the 145 it is 740 code..morning coffee mustve not kicked in.
