LS6 DBW conversion
Old Mar 14, 2012 | 09:28 AM
papa jiggy's Avatar
Default LS6 DBW conversion
This may be in the wrong section but I need help!
I just upgraded my 05CTS-V motor (DBW throttle body)
I added a TPIS LS6 intake with a 90mm nose.
Can I use LS3/LS7 DBW throttle body?
Its a DBW 90mm throttle body that I can find for cheap.
Otherwise I'm just going to convert to DBcable.
Thanks guys!
papa jiggy's Avatar
And if so- just a simple rewire with the LS3/LS7 pigtails or?
Old Mar 14, 2012 | 10:36 AM
scatillac's Avatar
Default CTS-V Throttle
Is the car an 05 V or are you doing a swap?
If it's an 05 V, you can use the LS2/7 (silver blade) 90 mm DBW TB by using Katech's adapter harness and the obligatory tune.
Old Mar 14, 2012 | 06:24 PM
papa jiggy's Avatar
The motor is currently in a 90 nissan 240sx.
So I can just cut my pigtails off and get some ls3/ls9 ones! sweet
I'm gonna use EFI live this year. What parameters need to be changed?
I don't want to buy it and then find out that its not compatible unless I buy an ls3/9 tac module because mine wont work or something.
