BCM (abs and active handling) tuning?
Old Mar 31, 2012 | 02:30 PM
3rdCoastPowerSports's Avatar
Default BCM (abs and active handling) tuning?
can you tune a BCM? obviously i cant with HP tuners so what software do i need to tune a BCM. I want to be able to turn off the abs and traction lights. I don't care that active handling and abs doesn't work i just want to turn the warning lights off. Anyone know anyone that does this or what software does this?
Old Mar 31, 2012 | 07:38 PM
BLK02WS6's Avatar
No, you can't tune the BCM... Pull the fuses to disable it and take the cluster out and unsolder the LEDs and take them out...
Old Apr 1, 2012 | 01:42 AM
Do you know where I can find a diagram of the cluster so I know which led to unsolder?
Old Apr 1, 2012 | 07:38 PM
BLK02WS6's Avatar
No, but when you take the cluster out, it isn't too hard to figure out which LED is the one you want to take out - you just unsolder them from the printed circuit board...
