detecting false knock
Old Apr 6, 2012 | 06:41 PM
puddingmmmmmmmm's Avatar
Originally Posted by gectek
I am not saying it is your gas, I am saying if you have too much timing, adding in more octane to the mix will show that.
That was directed towards racecars comment about having lower octane gas in it.
I thought octane additives only boosted octane by like .8? The highest octane I can buy at the gas stations is 93, so I can't even mix higher octane fuel in it. Local track has 103, but is closed for construction
Old Apr 6, 2012 | 06:53 PM
gectek's Avatar
If you can find some Torco Accelerator additive, it will increase it by enough to see if that is a problem.
Old May 2, 2012 | 07:10 PM
Thought I would update. After trying higher octane gas, and reducing timing the knock retard would not go away. Got a lt4 module that I put in when I got home from work today. Took it out and data logged it and have no more knock. Thanks everyone for the help!
