help w/TPS plug wiring
Old Apr 14, 2012 | 01:12 PM
mmarshall's Avatar
Default help w/TPS plug wiring
I am converting from DBW to DBC. I have figured out the IAC plug wiring, but I can't find a diagram of the TPS plug anywhere. I got the plug off a cavalier out of a junkyard and the wires are not the same color code as they are listed here:
http://www.lt1swap.com/cable_conversion.htm
my wires are black, dark green or blue, and yellow or gray. It is hard to tell the exact color as they are different colors under the tape vs at the plug due to heat.
I just need a diagram for the plug to get them in the right position. Anybody know where to find a diagram?
Old Apr 14, 2012 | 01:37 PM
LS13.5's Avatar
If you look on your plug it should be marked
A...B...C...
Gray Wire = A = Blue Connector 46 = 5V Reference
Black Wire = B = Blue Connector 54 = Ground
Blue Wire = C = Red Connector 24 = Sensor Signal
Obviously your connector color may be different (this is for an 0411 ECM), but at least you know what they are for now.
Connector plug is like this if you cant see the markings on yours
A.....B
...C...
Old Apr 14, 2012 | 02:42 PM
mmarshall's Avatar
Thanks I got it figured out now. I appreciate the help.
