why wont hp tuners read ECM?
Hook your HPTuners interface to the OBD2 port only, don't hook the USB cable.
If the green led doesn't light, you need to check fuses and power to OBD2 pin 16
a. your drivers aren't installed
b. you have a faulty usb cable
c. you have a faulty interface
Start by installing the drivers and if that doesn't work try a new usb cable if that doesn't work contact support.
This issue has nothing to do with the obd2 port of the vehicle in 99.9% of cases.
