Free PCM Diagnostics Progs?????
Old Mar 28, 2004 | 09:40 PM
ws.6kid's Avatar
Default Free PCM Diagnostics Progs?????
Just got a OBDII 2 Serial cable looking for free programs...
Are there any availible or at least some trail versions????
Old Mar 28, 2004 | 09:44 PM
66ImpalaLT1's Avatar
All cables are not the same, there are no free programs or trial versions because you need their cable.
Old Mar 29, 2004 | 08:56 PM
ws.6kid's Avatar
Why wouldnt a cable with a odb II connector and a parallel port on the other end not work??? How is the cable locked to the software exactly?? Seems logical to me that all the program needs is the data read from the PCM...
Old Mar 29, 2004 | 09:14 PM
jrp's Avatar
jrp
SN95 Director
when buying a program like edit/ hp tuner, atap, efi your paying for the cable not the software. the software will only work with its appropriate cable.
you didnt think you could get off that easys did you
Old Mar 30, 2004 | 07:39 PM
crainholio's Avatar
Check out scantool.net if you're looking for free software to experiment with. $85 or so gets you their cable and RS-232 translator box, the software and source code are freely downloadable.
Old Mar 31, 2004 | 01:29 AM
Because they dont just wire some pins together and convert some voltages. The cable has a controller chip and a specially designed VPW encoder to talk on the bus.
Each manufacturer implements this differently.
