simplify tuning for me....
Old Mar 29, 2004 | 12:50 PM
fastlif's Avatar
Default simplify tuning for me....
someone tell me cliff notes on tuning the fuel curve...If I want to fatten it up just a hair what table (PE vs RPM?) do I make numbers bigger or smaller? How much of a change should I make? Use percentage or just change the #'s by .00xxx? I have a wideband and it shows 13-13.5... I would like more like 12.8-13.0.
Thanks,
Old Mar 30, 2004 | 12:38 PM
fastlif's Avatar
28 views and not one response?
Old Mar 30, 2004 | 04:38 PM
deezel's Avatar
I assume you are talking about WOT fueling...
You can adjust the PE vs RPM table to change WOT fueling. Try 1 or 2% at a time and check with your wideband...
Old Mar 30, 2004 | 04:44 PM
fastlif's Avatar
yes, thanks, to lean it do I add or subract percentages? Seem slike I heard larger numbers are leaner?
