holley hp efi help
Old Jun 2, 2012 | 02:02 PM
  #41
NOS327's Avatar
When you change your stuff to custom and pick single pulse for your cam, do you use digital rising or falling?
thanks!
TJ
Old Jun 2, 2012 | 03:14 PM
  #42
Gray86hatch's Avatar
Rising
Old Jun 2, 2012 | 04:09 PM
  #43
RNation0001's Avatar
today i was dickin round with it and turned off the cam sensor. then got it running and decided to start from a stock fuel map, got out on the road and jarred it pretty good, got thru first and into secoond then the car lost all power and shut off , it blew the fuel pump fuse, im wondering if my fuel setup may be the cause of my problems, i still have no idea why it blew the fuse, im pulling out of the original sender in the top of the tank, from a holley billet fuel pump, maybe im getting air or something is why my afr is goin apeshit, but again i have no idea why it bleew the fuse put a new one in it and it started right back up and i drove home
Old Jun 2, 2012 | 04:34 PM
  #44
I would try to sump the tank or put it in the tank. You are asking alot to pull the fuel up that tube.
Old Jun 2, 2012 | 06:09 PM
  #45
yeah im gonna sump it maybe that will help things out
Old Jul 18, 2012 | 12:09 PM
  #46
NOS327's Avatar
Originally Posted by Gray86hatch
Rising
I had a Holley tech on the phone the other day to discuss various things and one topic was this starting/cranking time/dwell topic. All guidance given here was agreed to except choosing rising instead of falling. He said that "rising is a dirty signal, falling is always clean", and thus told me to pick falling instead.
For no other reason offering their $0.02 on the topic, I felt I should share in this thread..
TJ
Old Jul 18, 2012 | 09:46 PM
  #47
chiaj144's Avatar
I just switched my stock coils out for the Holley coils and the car wouldn't start. I switched the dwell time from 1.8msec to 5msec and it started as soon as I touched the key. Thanks for all the info guys.
Old Jul 19, 2012 | 12:51 PM
  #48
soundengineer's Avatar
I would Highly Recommend Turning down your dwell time back to 1.8ms
you will fry those coils by leaving it at 5.0ms
figure out where your real issue is instead of a band aid of a huge dwell time.
Old Jul 19, 2012 | 01:33 PM
  #49
chiaj144's Avatar
I turned it down. I jumped the gun on the dwell time fix. I bought the unit used and it appears the guy had the coils labelled wrong so the firing order was off. Going to try it again in a second with the dwell time down and the firing order fixed.
Old Jul 19, 2012 | 08:36 PM
  #50
NOS327's Avatar
Is that just Holley brand coils or will the long dwell hurt stockers too?
Old Jul 19, 2012 | 08:37 PM
  #51
stock lsx coils are good at 5ms....
Old Aug 23, 2012 | 03:36 PM
  #52
maxgee's Avatar
Simple question. Can the ECU connect to more than one computer? i have two labtops and wondering if I can use them on the same ECU?
Old Aug 23, 2012 | 04:43 PM
  #53
Yes you can use as many as you want as long as they have the software
Tim
Old Sep 8, 2012 | 10:47 PM
  #54
Buck-Strickland's Avatar
Default Confirming how to change the dwell time
I have a 5.3 with the stock truck coils, that slow starts too. I'd like to up the dwell time on the coils to see if this helps. Currently I have the base LSX 24x setup.
If I swtich to Custom:
Do I leave timing offset at 0 degrees?
Cam Sensor: LSx 4X or Single pulse? (I want to keep Sequential injection)
If Single pulse, Sensor type :Rising or Falling?
Output Setup: Type: DIS coil on plug then Dwell to 5.0msec?
I want to make sure I set this up correctly. Thank you any help in this matter.
