ls1 edit by me after a pro dyn tune?
If I buy ls1 edit could I plug in and change a few settings like shift point/firmness without disturbing the more intricate settings the pro set up?
I will be adding a shift kit after the dyno plus running at the track.
thanks!
thanks!
Yes you can run your own edit after the ignitial tune...Actually for a A-4 car it is good to have your own to play with shift points at the track(If you like fiddling to get the absolute best)
