HELP--BigStuff3 vs stock pcm for my setup..
Old Jun 9, 2012 | 10:48 AM
AAK z28's Avatar
Default HELP--BigStuff3 vs stock pcm for my setup..
trying to figure out if i would gain anything by using a bs3 compared to what im running now (stock pcm).
ls3 solid roller 416 13.5:1 compression
dry sump oil
mast black label heads
custom cam
mast 4500 intake
accufab 4500 tb
65lb injectors
diamond pistons with gas porting
howard rods
callies dragon slayer crank
jesel solid lifters
t&d machine rockers
lock-up th400
midwest chassis fab 9"
Old Jun 9, 2012 | 11:24 AM
edcmat-l1's Avatar
Biggest thing you would gain is the ability to run over 8 grand. That's about it.
Oh, and individual cylinder fueling, but that's not a huge factor in an N/A setup.
Old Jun 9, 2012 | 11:26 AM
AAK z28's Avatar
ya im probably not going to take it over 8 im going to stay right around 7800-8000
Old Jun 9, 2012 | 02:55 PM
edcmat-l1's Avatar
Then BS3 would be money wasted. If you have a 98 PCM, just do a 99+ PCM swap, and get yourself HPtuners. You'll spend a fraction of the money, and it'll run just fine.
Old Jun 9, 2012 | 03:38 PM
93camaro_zzz's Avatar
AAK, have you dynoed your car? I am really interested to see what a solid roller motor RIGHT around your cubic inches makes in power. PM me if needed. Thanks!
Old Jun 10, 2012 | 08:18 AM
AAK z28's Avatar
its gonna be quite a while before the car is dynoed or even started its gonna be on its way to see eric over at midwest chassis & performance to get a 25.5 cage and an extreme weight loss make over.
Old Jun 10, 2012 | 08:48 AM
Sounds good! We all know they will do it right!
