HPT help!!
Old Jun 24, 2012 | 10:56 PM
Scott123's Avatar
Default HPT help!!
It can not validate my PCM? If there is no fuse it can not locate the PCM (checked fuse first, my cigarette lighter works) I have tried with 2 different HP tuner cables.... Any one else ever experience this? I'm considering making a 2nd obd2 port like jumper harness unless some one a better solution?
Old Jun 24, 2012 | 11:52 PM
ATEURZO6's Avatar
Have you contacted Support... Also long shot but have you disabled the drivers on your computer?????? when you turn your laptop on press and hold f8 then it will beep a few times then select disable drivers... try that
Old Jun 25, 2012 | 10:56 PM
Scott123's Avatar
What drivers? No I haven't tried that, support just wanted a screen shot...
The car is a 1999 firebird formula. I don't know if that makes a difference?
Old Jun 26, 2012 | 02:07 AM
ATEURZO6's Avatar
what o.s. do you have ... try holding f8 like i said on the start up of your lap top.. then there is an option of disabling drivers...
Old Jun 26, 2012 | 06:20 AM
edcmat-l1's Avatar
So did you send them a screen shot?
Old Jun 26, 2012 | 08:27 PM
Scott123's Avatar
No, I haven't made another attempt @ it. I was hoping to this weekend. Depending on work. It's not my laptop or I'd be sending then countless screen shots.
