25.6 afr setting and runs great. why
so if i set my afr to 14.68 it runs super rich but if i set it to 25.6 it runs great. just before it gets in to boost then goes super rich but gets through it then its fine in boost but still a little rich at like 11.0. whats the deal? set up is a stock 2001 5.3 with ls6 intake with 36lbs injectors. t72 turbo ar.96. 50mm rps bov. 50mm wastegate. running 92 octane
Purely a guess, but the injector flow rate in your tune does not match the actual injector flow. This means, someone changed out the injectors to a much higher rate but did not change the tune to match.
That could explain it.
That sounds about right. That is, if your wide bank is accurately calibrated which many of the cheap ones are not. What conditions exactly are causing the problem?
at about 2.800 rpm if i give lots of petal it bogs goes to 10.0 stumbles, ill hold it then it catches up makes boost then takes off.it takes like 3 seconds.but if i ease it up to like 4000 rpm then it only bogs for a second
It's in the beginning stage of tuning but still can't figure out why the afr has to be set so high. It's with hp tuners. Not sure if it needs to set to 14.68 then wright entire. Instead of write calibration only. The stft openloop is on. Not sure if that should. Be turned off. Going sd. No maf.
WOW!!!! Plz do yourself a favor and tune the MAF/VE tables ASAP. Try searching for the correct injector data for the 36lb/hr injectors or swap them to some ford SVO Green Top 42's. Theres TONS of data out there for the green top injectors.
Some ppl used to scale injector data by playing with the AFR stoich setting that way but it makes your Power Enrichment figures a little more difficult to figure out.
Put the stoich command back to 14.68.
Just going to get 80lb injectors and go e85. And sees here's that gets me,at least with new injectors I'll get the info I need for them. Possibly have MAPerfomance tune it for me.unless someone knows something I'm missing. I'll try to post current tune or what if been trying to correct
http://ls1tuningguide.com/index.php - this is a start.
http://www.masportspeedshop.com/serv...-tuning/Detail - buy this book and read it 10x
There is more to tuning than just changing the afr numbers.
