C5 Z06 vs C5 Vette program?
Old Jul 10, 2012 | 01:51 PM
npilot1975's Avatar
Default C5 Z06 vs C5 Vette program?
Is there a difference between the C5 Z06 and the standard C5 PCM program? I bought a Z06 chassis but the PCM I recieved is from a standard vette. I have to get VATS etc programmed out, but will programmer have to do anything else?
Old Jul 10, 2012 | 07:33 PM
BLK02WS6's Avatar
Yes, there is a difference. I would have them put a Z06 tune in the PCM...
Old Jul 12, 2012 | 08:31 AM
SKULL's Avatar
so all it would need is a z06 tune or a z06 pcm?
Old Jul 12, 2012 | 10:13 AM
SSpdDmon's Avatar
I don't think the hardware changed between 1999 and 2003 (I think '04 was different though). The OS and tune files (settings) changed. But, you should be able to swap in the right OS/file with a full write no problem.
Old Jul 12, 2012 | 06:23 PM
BLK02WS6's Avatar
Yes, the 04's are the 1MB PCM and the 99 to 03's are 512KB - He needs the OS & calibration flashed in that match the engine/sensors - hopefully they at least gave him the correct PCM, even though it has the base C5 tune in it...
OP - what year is the chassis/engine? what year C5 is the PCM from?
