what should may air fuel ratio be
thanks,mike
So there is startup enrichment, and once it's warmed up it leans out a little and runs at 14.62. Dialing my PE (POT) in now to 13. Should richen up a tad on WOT.
But yours sounds like it's dialed in the same.
As for what the numbers should be (when using a wideband sensor/guage) on a bolt-ons car, 14.5-14.9 is target range for idle and part throttle. When the engine is under load and power enrichment kicks in, 12.7-13.0 is target range. Higher numbers are leaner and you don't want to go leaner than 13 at WOT.
