p0200 code help
Old Jul 21, 2012 | 09:29 PM
irishws6's Avatar
Default p0200 code help
greetings all,
car seems a little hesitatant/spluttery and jerky especially when moving from 1st to second gear and then car just threw the code p0200, ive searched and realise what the code means.
however where do i even begain to check for problems??
the car is only driven maybe once or twich a month for less than 100 miles,
i first thought it may be bad gas or gas sitting in tank fouling up injectors??? would this cause the code and hesitation??
i also spotted that my pcv valve grommet is split open woild this cause the code, remember reading somewhere about this causing the problem??
any help or imput greatly appreciated
