Throwing Codes
Old Jul 27, 2012 | 12:31 AM
oxblood!z28's Avatar
Default Throwing Codes
What's up you guys I need some assistance. I just recently started my car after a good year or so. I've been on and off with it for little bit, but for the most part it started up on the first try. I checked the oil on the second start up and gave it about a quart more. On the third try It started up just as good as the first and second tries. I had the rpm gauge jumping around, but that`s probably cause I need a re-tune.On the 4 try It didn't started. All I heard a click coming from the driver side engine bay. Today I scanned it using a obd2 sensor from orielys and it gave me these codes (C0240)PCM Traction Control Not Allowed (ETS) and a (C0237) throttle position signal malfunction. Could this be the reason why my car isn't starting? Your input is needed thanks.
Old Jul 29, 2012 | 11:29 PM
Cleared the codes car still doesn't start. Wth. What's happening with it?
By Brett Foote | 2026-06-04 05:00:17
