big stuff 3 tune
Old Aug 25, 2012 | 10:35 AM
Silver6.0's Avatar
Default big stuff 3 tune
ok guys. i just bought a 3rd gen camaro that has a ls swap with big stuff 3 on it. the tune seems to be way off. i was wondering if any body could email me a tune that would be closer and that i could work off of. im gonna list the basic build and if anybody has anything close i would appreciate the help
it is a built 347
absolute speed stage 2 5.3l heads
t-rex cam shaft
gm high performance single plane
eldlebrock 1000cfm throttle body
diamond high comp dome pistons (i have specs if needed)
bore 3.905
stroke3.622
rod length6.125
from my calculations about 12.96:1 comp
th350 trans
4.10 gears
and i have 28" tall tires on it
if any more info is needed just post up
thanks alot guys/gals
Old Aug 28, 2012 | 12:19 PM
Silver6.0's Avatar
uhm anybody?
Old Aug 28, 2012 | 05:08 PM
SNIPER-MAN's Avatar
i dont think you will get a good tune like that,,, u should take the car to Dyno Shop for proper tuning otherwise look for someone on your area because he will need to log the car first then set the right tune to it
and i hope u can find someone that could help you with a tune from similar setup
Old Aug 29, 2012 | 12:00 PM
Silver6.0's Avatar
Well I feel that if I could get a starter tune that is kinda closei could fine tune it. Or at least give it a shot b4 I pay someone to do it.
Old Aug 29, 2012 | 04:53 PM
Old Geezer's Avatar
Have you tried or good friend, Google??
https://www.google.com/search?q=Big+...rchBox&ie=&oe=
