Engine Swap. Engine cranks But wont start.
then finally got around to putting the engine back in the car.
Tried to turn on the car but it cranks.... but wont seem to start.
Fuel - Check ( there fuel going to the lines didn't check the pressure tho.)
Spark - Doesn't get spark.
PCM - Not sure. My HP tuners seems not to be able to reconize my cars ODB2.
BUT does get power when I connect it to the ODB2 slot. ( So i say there is power...)
Another note when I use my HP tuners .... its doesn't recognize my ODB2.
(is the PCM fried?)
Or possibly did i miss connecting a sensor and thats causing the car not want to send spark to the plugs?
thanks,
Ws6kid.
When I swapped my motor I left the crank sensor unplugged and had no spark but my hp tuner connected to the OBD2 port. That's how I found the sensor... Low voltage, crank sensor.
Not sure about the obd2 not working but i would go over all the plugs and grounds first.
turned out the PCM was fried.......
i tried a buddies PCM and the car turned on with no problems.....
thanks, guys.
