MAP 0108 Code HELP
http://forums.corvetteforum.com/c5-t...nse-issue.html
I'm going to try a new MAP sensor then drain the gas since this issue began less than 2 minutes after I put gas in the car. I'm out of suggestions and that was the only code I've got to work with. Time to start throwing parts at it
P.S. Is the green wire on the MAP sensor harness suppose to have no power at key on engine off ? Orange had ground and gray had 5.04 volts.
