2000 Corvette N/A E85 - timing advance?
The car generally drives and idles nice, but occasionally will pop/backfire out of the exhaust randomly at idle. Long term fuel trims are in the -4 to -5 range at idle and STFTs hover near zero. The car only has around 15-16 degrees of timing at idle. Could it be that it wants more idle timing to fully burn the fuel?
It has between 26-28 degrees at WOT, which also sounds a little low to me for E85.
Thoughts? Thanks!
EDIT: plugs are TR6s of unknown age, and wires are some Moroso ones, also of unknown age.
I would try to bump the idle timing up to near 20* and see how it likes it.
