Disabling ECU Features
Old Sep 14, 2012 | 07:09 PM
zuffen's Avatar
Default Disabling ECU Features
I have an lS3 running without the BCM.
When I scanned it this morning I had 18 fault codes.
4 of the codes relate to the fuel level sensor having a high reading. As I don't use the stock sensor and the pins have been removed from the harness I can understand that.
2 of the codes relate the fans turning on as soon as the car starts up. I know this can be adjusted via EFI Live.
The last 12 relate to the missing 3rd and 4th o2 sensors and/or their heating circuits.
Can I hae the settings changed in the ECU, via EFI Live to trun off the fuel level sensor codes and also delete the 3rd & 4th o2 sensors?
Old Sep 15, 2012 | 02:21 AM
Bigtoyz's Avatar
under engine diagnostics I believe
Old Sep 17, 2012 | 10:42 AM
cyipher's Avatar
All of those can be turned off with efi live
Old Sep 19, 2012 | 04:25 AM
zuffen's Avatar
Thanks Gents, I'll get my tuner to do it all.
