Dyno Tune
Old Apr 7, 2004 | 06:44 PM
LS1999pewterZ's Avatar
Default Dyno Tune
I just installed my headers awhile back and I was wondering if you need to get the car dyno tuned after or if the car is fine and getting a dyno tune is really just needed after you do a cam and all the other goodies
Old Apr 7, 2004 | 07:05 PM
PongoX11's Avatar
Yeah, you will pull a little bit from a dyno tune after headers. However if you are planning on doin a cam, you might as well wait till then. A dyno tune will be a much better investment to a cam'd car
Old Apr 7, 2004 | 08:34 PM
M6HuggerSS's Avatar
whats your AFR.....that will help you decide also! if your way lean, GET A TUNE!
most re-tunes arent much anyway....
Old Apr 7, 2004 | 10:57 PM
SapphireHawk's Avatar
Most people after headers run on the richer side, but it always a good idea to check it out just in case.
Old Apr 8, 2004 | 12:13 AM
Revelation222's Avatar
I was running crazy lean after my LT install, however most seem to run rich. Im just glad I didnt get on it hard before my tune. That could have been bad.
Check your a/f ratio and go from there.
Good Luck and Take Care.
Old Apr 8, 2004 | 10:11 AM
2002 Trans Am's Avatar
Its a good idea, i'll be getting tuned this month or the beginning of next month. About a year since I installed my headers. I figured since i'll be putting in the converter, nows a good time to get it tuned
