Help.... Ls2 Cyl. 5 and 8 Multiple misfires P0300
Here's the facts: 05 LS2 GTO 6 Speed New GM Crate Motor 6000 miles
Only Mods are Cold Air Intake and Muffler Delete Stock Tune.
Swapped injectors from cylinder to cylinder, All New Coils, New Wires,
Tr55 Plugs gapped to .057", New Delco O2 sensors, Valve springs are
good, Push rods not bent, No bent valves, Leak down test is perfect,
perfect compression.
Car will miss heavily at around 1900 to 2200 rpm's on cylinders 5 and 8
only verified with HP Tuners scan. Doesn't really feel like it really and
really can't hear it in the exhaust note. Car doesn't lug or have any lack
of power??.
All the plugs look great and there is no Knock. Im thinking its gotta be
electrical? Car does Idle a little rough at times though...maybe im
paranoid though.
Here is what my possible next steps are:
1.Replace the Crank Position sensor and perform a case learn?
2. Cam Sensor??
3. Any Ideas or suggestions please feel free to share....????
Driveline Vibration IE: Flywheel / driveshaft ect.... MIGHT be a good bet because it
only does it at the certain RPM's 1800 to 2200ish. Does that sound logical???
I got a cam sensor for $30 I am going to replace that this afternoon, was talking with a tech at a dealer and he said that he seen a few cam sensors that would only mess up at certain rpms? anyway its worth a shot, only $30 plus then I know its a new sensor anyway.
Thought I would post the results for future searches.
Installed Cam sensor and went 70 miles in the RPM range that is was throwing the code.....and the code did not come back. Before the code would pop up every 3 to 4 seconds while cruising in that range.
Hopefully this was it....crossing fingers.
Low and behold the symptoms are totally gone. We couldnt get HP Tuners to perform the relearn for some reason?
