knock sensor testing
Old Oct 2, 2012 | 05:55 AM
hotparts's Avatar
Default knock sensor testing
Hi guys,
i have the two knock sensors aside the motor (LS2 in a Corvette C5).
If they wouldn`t be connected right or if they wouldn`t work or work correct, would i get a PÜCM code and what code, or is there no security testing for them?
Old Oct 2, 2012 | 11:56 AM
MontecarloDrag's Avatar
A sensor may be bad and not trip a DTC
If they aren't connected they will trip a DTC code for sure
Old Oct 2, 2012 | 01:26 PM
hotparts's Avatar
Hmm and what is the best way to Check? What DTC would show up?
Thank you
Old Oct 2, 2012 | 09:40 PM
joecar's Avatar
View the knock sensor counts on a scantool while you tap the front of the heads with some object (like a wrench).
Old Oct 3, 2012 | 01:13 AM
hotparts's Avatar
ok, i try it
