ABS and BRAKE lights on!! HELP!!!!
Old Apr 9, 2004 | 01:32 AM
98sspullin'em's Avatar
Default ABS and BRAKE lights on!! HELP!!!!
my abs inop light stays on but as soon as i move the car, the brake light comes on... jayson at mti said it was the plug on top of my rear end , i checked it and everything looked fine... and it is still on.. where else can i check and where do those wires run?? that light is just drivin me insane, both of them...
i just dont like drivin my car with the lights on....
Old Apr 11, 2004 | 11:04 AM
GrapeApe's Avatar
check the wires that go to the sensors --i accidently cut one with a grinder once--also you might be able to clean the sensor--or it could just be a fuse
check the abs fuse
Old Apr 11, 2004 | 11:47 AM
98Blubrd's Avatar
in my old LT1 camaro the ABS inop light came on because the brake light on the spoiler was out. Once I replaced the bulb everything was back to normal. Might want to check that.
Old Apr 12, 2004 | 09:54 AM
PAGregSS's Avatar
I had the same problem once. It turned out that the ground stud was loose. It was the bolt on top of the drivers side fender that has a ground wire running to it. Check that to see if it's tight.
Old Apr 12, 2004 | 11:17 AM
LS1INSIDE's Avatar
are you on any kind of e.t. street or tall tire?
