idle adjustment
Old Oct 5, 2012 | 04:05 PM
jt_2002_ta's Avatar
Default idle adjustment
Is it possible to adjust idle by the set screw on the throttle blade and then do a TPS relearn? Or does it need to be done with tuning software? It idles at 1000 according to my window switch, kinda want to hear the cam better at idle! Thanks
Old Oct 5, 2012 | 04:31 PM
outkast6991's Avatar
you need to change the desired idle speed in the computer.
Old Oct 5, 2012 | 06:38 PM
jt_2002_ta's Avatar
thats what i thought. i guess i should invest in hp tuners and start learning how to do this stuff!!
Old Oct 5, 2012 | 07:14 PM
i'm using efi live. it is a steep learning curve but if you use common sense and don't make huge changes it is doable. i'm lucky and have a good friend that is steering me in the right direction
