auto VE for V2. what PID's
Old Oct 16, 2012 | 07:01 PM
rumblebox's Avatar
Default auto VE for V2. what PID's
i can't find any information anywhere on how to use my LC-1 with a serial connection on V2. anyone?
Old Oct 16, 2012 | 07:26 PM
BLK02WS6's Avatar
Have you been on the EFILive forum? There are a bunch of tutorials and help over there...
Old Oct 16, 2012 | 07:40 PM
rumblebox's Avatar
All the ones ive seen are for V1 or for analog connections.
Old Oct 16, 2012 | 07:47 PM
BLK02WS6's Avatar
http://forum.efilive.com/showthread....rial-Wide-band
Old Oct 17, 2012 | 07:33 PM
ACCLR8N's Avatar
You will need a null modem adapter to join the LC-1 serial cable to the V2 serial cable. Or you can buy the single dedicated cable.
With the V2 connected to your computer, launch V8.2 scan and tune. Doesn't need to be connected to LC-1 or car. F6-->F6, check box "Automatically select all external digital PIDS". Save and Program.
Then F8: Serial I/O. Com Port: WIDEBAND. Display layout as you want. Wideband Type: Innovate.
Old Oct 17, 2012 | 07:36 PM
rumblebox's Avatar
Have all the hardware. I'm talking about PID's.
Old Oct 17, 2012 | 08:02 PM
ACCLR8N's Avatar
In V7.5 scan and tune PID list, it will be EXT.WO2AFR1, EXT.WO2LAM1, or EXT.WO2EQR1
In V8 for BBL it is the same without the "EXT." prefix
Old Oct 17, 2012 | 09:23 PM
SYRacing's Avatar
Does the above listed diagram work? I see all these rumblings of needing a null modem adapter..My plan was just to goto ratshack/home depot/kmart and get a RJ12 cable, ohm it out and solder onto the supplied jack that came with my lc1
Old Oct 17, 2012 | 10:36 PM
joecar's Avatar
With V8 S&T, did you go into Devices and set coms to Wideband and Type to Innovate (as said above)...?
And the tuning pids (BEN) you want are provided in the calc_pids.txt file in post #1 of the Calc.VET thread (under Gen III).
Old Oct 17, 2012 | 10:39 PM
joecar's Avatar
If your NBO2 and MAF are still enabled, and your wideband is installed, then start off by doing the Calc.VET tutorial, it gives quick results (corrects MAF and calculates VE in one log session... but do read the thread, it helps you get good data).
Old Oct 18, 2012 | 09:05 PM
rumblebox's Avatar
Made my own.
Old Oct 20, 2012 | 05:16 PM
joecar's Avatar
Cool
Old Oct 21, 2012 | 02:42 PM
rumblebox's Avatar
Does it matter than im running SD?
Old Oct 21, 2012 | 06:30 PM
joecar's Avatar
If you're SD then you're constrained to doing the AutoVE tutorial...
but you can still (and should) use the calc_pids.txt file from the Calc.VET tutorial
(use the pid CALC.WO2BEN instead of the BEN pid mentioned in the AutoVE titorial).
