primary ve tuning
Old Oct 22, 2012 | 11:29 AM
SStressin's Avatar
Default primary ve tuning
starting to tune my 00 camaro with a ls 383 big cam etc.. turned my maf frequency to 0. and used histogram 3 and reset ltft. first starting out with my ve table in my tune all the numbers are pretty high anywhere from 50-90. multiplied by 50 percent n got them down to around 50-60s for the most part then scanned it and around 2000-2400 rpms and 30-50 kpa in my histogram i keep getting big negative numbers like -12 etc. so i add all those values to my chart and still no difference. my chart is starting to get down really low numbers in the teens n 20s. and still wants to go lower then that.. no matter what i do keep getting large negative numbers in my histogram.. am i doing something wrong? normally what should these values be?
Old Oct 22, 2012 | 01:40 PM
foff667's Avatar
LS1TECH Sponsor
in wot cells depending on the combination & conditions 90-120 is pretty common.
Old Oct 23, 2012 | 09:16 AM
SStressin's Avatar
Figured it out did it all wrong the first time. Got from 0-4000 rpm pretty perfect gotta do from 4-7000 now!
