E85 & PCM operating system questions.
Old Nov 20, 2012 | 09:45 AM
KAPLOWW's Avatar
Default E85 & PCM operating system questions.
I've done a good bit of reading, and have written my tune for the first E85 fireup coming up here probably on wednesday or thursday.
I DO NOT want this thread to turn into another E85 vs. Gasoline thread that clutters up the search function.
My car is a 1999 C5 LPE 650 twin turbo. With everything in place for the increased demand in fuel. Bigger injectors, pump, and a boostapump.
I'm not looking to turn up the boost. I just want the added security of E85, and a little more timing in boost.
My question is mainly concerning the PCM.
Is it possible to load up a flex fuel operating system that detects the change from gasoline to E85 automatically without the use of the flex fuel sensor onto my PCM?
Would I need to swap in one of the flex fuel PCMs?
I really want to get this implemented so I can combine my tunes, interpolate, and not have to worry about ethanol percentages.
I'm currently running a 2 BAR SD OS on 93, and it is running REALLY well. I've spent a lot of time getting this thing dialed. Night and day difference than the stock LPE tune.
I don't think I have seen this topic specifically addressed with HP tuners. If you know where the info is, please show me the way. I don't mind reading, but I have yet to find it, and have searched A LOT!
Thanks
John
Old May 24, 2013 | 01:52 PM
roastin240's Avatar
Bringing this back from the dead.
I would like to accomplish the same exact thing. I am familiar with Haltechs approach using dual fuel and timing maps and interpolating between the 2 to determine the value at that point in time. They use an in tank ethanol concentration sensor.
Now, GM has E85 vehicles, how do they do it? I would like to get a PCM from a E85 complient vehicle and try to calibrate it with HPTuners. Is this possible? Someone on here has done this I am sure. Anyone?
Old May 24, 2013 | 03:46 PM
murphinator's Avatar
I havent seen anyone using a flex fuel tune w/ethanol sensor adjusting to ethanol % real time yet ( I would love to stand corrected though lol)
I have seen people using the zeitronics ethanol tester or test tube method to determine actual % of e and adjusting stoich as needed , 2 or 3 tunes should cover e70-e85(what can come out of an e85 pump) you would think and maybe with monitoring only require a reflash at time of seasonal blend changes???
I live in a state with no e85 but have seen the amazing results so I peek in at all these threads so I know whats up/get educated for if and when we get it.
