Knock Censor Codes.... pls help
Old Apr 14, 2004 | 01:38 PM
BBADWS6's Avatar
Default Knock Censor Codes.... pls help
I know there have been several post about this in the past, but ive got a few questions that havent been answered.
My car just started throwing both P0327, and P0332 codes. I dont think the sensors are bad since the codes are being thrown at the same time. Its strange that every time the SES light comes on im not getting on it, its usually around 2000 RPMs.
When i reset the computer the car will run fine for a day or so, then it will throw the codes again. What is the possibility that mabye the wire is pinched, and if it is not that, is the PCM the next thing to check.
Thanks,
Chris
Old Apr 16, 2004 | 07:59 AM
Predator's Avatar
It's either a pinched wire or the pcm. If you never had your intake off, it's most likely not the wire but the pcm, and probably corroded KS pins.
