Need help ASAP please!!!
The car has been running fine with its tune for well over a year. Its just now that it started random.
Update on the situation I changed the O2 sensor on bank 1. it seems a little better. But not enough.
If it's all of a sudden dumping fuel, either you have an O2 issue, or weak spark, or maybe a sticking injector issue. All of which you should be able to log the necessary PID's to monitor.
Your Power Enrichment table is set to 1.229 across the RPM range.....that's where your 11.X:1 A/F is coming from. I see its a nitrous tune by the name of the file so that explains why youre commanding that A/F.
You also have PE delayed below 3200rpm's which may explain why you weren't seeing this all the time.
COT is disabled in the tune.
LS6 manifold, Ported Throttle body 85mm, 4 inch cold air intake, and 3 inch exhaust on a built 4l60e
If u can fix what u think is wrong it will be great man...
Thanks for the help big time.
If u can or wanna contact me ill pm u my phone number no homo lol
The car use to run AMAZING 12.9 all motor and when i sprayed it it will be 11.5-6 afr.
Again the car use to run perfect for over a year and a-half, I had the car down for a month while building the trans again and when i got it running is when it started.
No problem man give me a little bit and call if u can. I have to install it in my other laptop.
the man helped me out step by step... I saw the PE tables way off. He helped on explaining what this does sense im new to HP tuners.
I got in my car and did some pulls around the neighborhood sense i live right off the highway
. And here is the difference on the tune and here is the log of the last corrected pull.Air and FUEL is now at 12.9-13.0 all across the board over 2000rpms.... well so far so good.
If you see anything I MEAN ANYTHING please do tell and also i disabled abuse mode for the transmission. If u see my trans tune and see something please tell me i wont be mad at all. After all I'am learning HP tuners
Glad to hear you got it coming around.
If u could guide me towards where to change it or disable it.
You said the issue happened overnight... kinda leads me to believe you have a broken valvespring so it may be a good idea to pull the valve covers to at least inspect to make sure everything is okay. 6500rpm is hard on the little stock beehives.
EDIT*** I didn't even see the second page of comments haha. Sounds like your on the right track. I normally disable LTFT all together so they cannot have any adverse affect on WOT fueling. Normally if the LTFT learns + corrections they will transfer to WOT fueling. If they learn - corrections they will never pull fuel from WOT and will 0 out. When you disable them all together they never learn. The best practice is to disable them and then use STFT or full time open loop with a quality wideband to dial in your VE and MAF then you can verify partial throttle fuel trims and your WOT fueling will be purely open loop actual = commanded.
So I put the car on the dyno. And as I got to 4500rpm/5500 rpms dramatic power loss even doe a/f stayed the same. I added some timing on does spots and dramatically fixe the issue. Granted I have short term and long term both disabled.
Will post up picture of the before and after dyno pull. So now the car is back at it again doing the same ****.... It's really agrevating the hell out of me
Notice as the air and fuel ratio is perfect between 12.80-13.00
Blue is before i added timing to the map.
Red is after i added timing.
Now i was considering the fact that my exhaust is pretty kinked when the drive shaft snapped on me.
Does anyone think this could be a flow restriction problems?
and when i do a damn log i get 15%+ fuel on the LTFT even though its not enabled
