Diablo tune for Procharger?
Perhaps the tuner simply wants to start with a knock stock file....
I guess Im not following where you are going to get the procharger tune from?
if you get it in our format, it can be loaded with the Predator.
If so, no wories.
If you changed gear ratio in the PCM already, thats what the tool will see as the stock value, and it will not change it.
Just load the procharger tune and enjoy.
If you want to make further chnages from there, you can fine tune with DST afterward.
Thanks
