Engine will not start
Old Feb 27, 2013 | 11:06 PM
RocketKing's Avatar
Default Engine will not start
I have a 2004 LQ4 in a 1967 Chevy truck. According to the diagnostic machine there is power while cranking but as soon as the engine tries to fire (you can hear it fire a few cylinders) the computers turns off then immediately back on for some reason. Do you have an idea what would cause the computer to turn off/on when the engine fires off? BTW the indicator light comes on when the key is turned on but goes off during crank, any ideas?
Thanks
Old Feb 28, 2013 | 09:36 AM
gagliano7's Avatar
Do you also have battery power going to the pcm?
Old Feb 28, 2013 | 02:46 PM
RocketKing's Avatar
Yes I have battery power to the pcm.
I should also state that the truck was starting and running but I unhooked the computer to rework the mounting bracket and now it will not start. Any chance I damaged a pin when I replaced it?
Old Mar 1, 2013 | 09:28 AM
gagliano7's Avatar
Sound like that could be your problem.Could be a loose connection.
Old Mar 10, 2013 | 11:49 AM
gMAG's Avatar
Did you find the problem?
Old Mar 11, 2013 | 09:07 AM
RedWS6 00's Avatar
Does the original bracket before you reworked it look like it gets a ground from the chassis to the case of the PCM? Perhaps by reworking it has lost the ground?
