Gauges reading really funny.
Old Apr 7, 2013 | 09:05 PM
Sk8phreak88's Avatar
Default Gauges reading really funny.
I've got a problem with my gauges. I just got the car back together after having a new transmission pump installed and getting the converter fixed by yank. The car has a battery relocation kit so the battery is in the trunk. This is a pull from stop light to about 40-45mph (GPS because as you'll see my speedo doesn't read correctly.) And only a maybe 1/4 throttle. I wish I had enough power to do what it does.
The car is a 98 LS1 that has a cam and a 4l65E built by ACE racing out of Texas and 3.42 gears.
The voltage gauge as you can see reads really low. I pulled the negative cable off of at the battery to see if they car would stay running and it died the second I pulled the cable off. So I'm assuming I need a new alternator. But do you guys think that my alternator problem would cause the gauge to do what they are?
I have no codes what so ever as if I missed a plug or anything.
Any thoughts on what it could be?
Thanks for any input!
Old Apr 8, 2013 | 05:32 AM
Pacer Racer's Avatar
Lets hope you didn't burn up any electronics by pulling the battery cable. You never should do that on a modern car. Get a voltmeter and learn how to use it. By the way an unloaded alternator can put out over 100 volts.
Old Apr 8, 2013 | 07:15 AM
Old Geezer's Avatar
Start w/ checking all the grounds. And, what Pacer said^^^^^^^
W/ the trans having been taken out, I'd look at the grnds at the rear of the head.
Old Apr 8, 2013 | 09:08 AM
I couldn't find my multimeter and I was in a hurry to try and see if I could narrow down my problem. Everything is working the same as it was before so I don't think anything fried. I didn't unbolt any grounds either. All I unplugged was the 3 plugs and the vacuum line to the trans. And then the o2 sensor to get them out of the way.
