Prosport Wideband Problem?
Old Apr 20, 2013 | 02:24 PM
Ferocity02's Avatar
Default Prosport Wideband Problem?
Finally got around to hooking up my Prosport Wideband (link below). I powered it up in open air to make sure it was getting a reading and that it was heating up. On first power up it was bouncing around between 17.2 and 16.1 in about 2 second intervals. I expected it to say 20 in open air. So I did the calibration process and it did the same thing. It kept doing this for a minute or two before I turned it off. Heater seemed to be working.
Then to test the sensor I put it in the tail pipe of my motorcycle, about 4" in, just to see if it would respond (I don't have an O2 bung for the wideband yet). It was in the tail pipe for a couple minutes and it was bouncing around between 14 and 16 fairly randomly. I pulled it out and then it was bouncing between 17 and 20 in about 2 second intervals.
Is this normal? Do they need to be very hot to read correctly?
Gauge: http://prosportgauges.com/wideband-a...ratio-kit.aspx
Directions: http://prosportgauges.com/instructio...alwideband.pdf
Old Apr 20, 2013 | 05:13 PM
salemetro's Avatar
Sounds like it's defective. I've never used that brand, but I'd think that it should have read max lean (22+) in free air. Usually, I prefer the NGK AFX unit....which has a better NTK sensor. After that, I would suggest the Innovate LC1 for a permanent gauge-style installation. I've never had any problems with the LC1, but a few here have.
Just my $.02
