Truck PCM with Corvette DBW will it work
Old Apr 25, 2013 | 09:34 PM
john59's Avatar
Default Truck PCM with Corvette DBW will it work
Hi Guys,
Just getting around to finishing my S10 Blazer LQ9 6.0/4L80 Swap and was wondering if this would work, I was told it would but know that you guys would know for sure
I have a Red and Blue Pcm Harness that was made for my swap it is a stand alone piece setup for 4L80, I'm using all C5 2000 Corvette parts meaning TAC, Gas Pedal and Throttle body, is it possible to use a 6.0/4L80 Truck PCM and still have my Throttle body and such work correctly? I've been told it would if I switch a couple of wires at the throttle body because it works in reverse of truck throttle body.
If not what is my best alternative, thanks for the help.
I have HP Tuner with 8 Credits left
2000 LQ9 6.0 with 243 heads and 2004 ZO6 Cam LS6 Intake
4L80 is 1999
John
Old Apr 27, 2013 | 01:34 PM
john59's Avatar
Nobody ???
Old Apr 27, 2013 | 02:12 PM
MontecarloDrag's Avatar
Short answer, yes
But you need the right combination of wiring/PCM/operating system to make it work.
Old Apr 29, 2013 | 04:44 PM
Joe1967ls's Avatar
heres a link that might help you out,
http://www.lt1swap.com/cable_conversion.htm
Old Apr 30, 2013 | 06:34 PM
john59's Avatar
Thanks, spent lots of time there when doing this S10, HP Tuners Site got me hooked up.
Thanks All
