SES Light
I'm thinking MAF or o2 sensor issues...
FYI...it's got long tubes and ORY.
if it is the o2 sensors, do you guys recommend running the corvette o2's instead of extending the stock ones? Last edited by TheOrangeGuy; May 7, 2013 at 09:20 AM.
Update... I deleted all the codes and it drove 100% normal for a few minutes then started doing it again. I got a new C5 corvette o2 sensor I'm going to drop in the passenger side and I'm going to clean the maf...hopefully that will do it...
Any other suggestions would be great.
Thanks
Maf is cleaned...went ahead and cleaned the throttle body too while I was in there. Passenger side o2 sensor had water in the connector because the wire was hanging way too low...I'm gonna wait about an hour and let the connection air dry and then install the new passenger side o2 based on what I've found so far...I'll update when that's done.
Last update...
After doing what I said above, the car runs fine... pretty sure the passenger side o2 was the main issue.
