VE table question
Old May 13, 2013 | 07:37 PM
2000 TA owner's Avatar
Default VE table question
Yea my first time logging fuel I unplugged the maf and copied the spark table loaded the tune in my car reset the fuel triims when I took it out for a ride it shifted real hard does this put the tranny in a default mode to not worried about it just curious if this is whats happening
Old May 13, 2013 | 07:54 PM
BLK02WS6's Avatar
Yes, it is happening because you are in speed density...
Set the Transmission Diagnostics->Transmission DTC Fault Max Pressure Enablers
• P0101 ‘No’
• P0102 ‘No’
• P0103 ‘No’
Set the Transmission Diagnostics->Transmission Failsafe Enablers:
• Set all airflow related enablers to ‘No’ to prevent the transmission from going into failsafe mode due to the MAF being disabled.
Old May 13, 2013 | 08:14 PM
is ok to leave it alone just to do my logging
Old May 13, 2013 | 08:20 PM
topgun542's Avatar
I Would Change Those Settings... Your Trannys Shifting AT Max Line Pressure Every Shift Not The Most healthy Thing lol
Old May 14, 2013 | 05:14 AM
thanks for the info
