L92 w/ e38 in 72 cutlass - P0606 error code
after start-up i was having issues with it running really rich. when comparing the pressure vs flow rate table for an 08 and 09 escalade, i realized they were significantly different. i changed the table to match the 08 settings. the engine started up much easier and was running much smoother. i didn't think much of the difference until reading other posts about the p0606 code and it eliminating control of the pedal.
to add to the confusion, i am using a pedal from a 2007 monte carlo ss. i get full function of the throttle blades, but the scan tool always starts at 20+% throttle position and only goes to 80+%.
from what i understand from other posts, the mismatch of the PCM, engine, and pedal may be causing the P0606 error. as i understand it, the throttle body was the same in 2007 and 2008 escalades, and then different in the 2009 escalade.
finally the question: I have another PCM from a 2007 truck. Will this PCM work with my current throttle body to eliminte the P0606 error?
any thoughts are appreciated.
i am going to read the calibration on the other E38 PCM i have and hope it is something that will help me out. i may end up having more issues trying to make the 2009 PCM and 2009 throttle body work correctly in this engine. i am also still hoping to confirm what year the engine is.
i will share my results of trial and error.
Engine year shouldnt matter as long as it's a 58x reluctor (all L92s are), so you should be ok. It matters only to figure out what injectors are in it (you can read the injector part #s off them too and figure it out that way).
