ses light
Old Apr 25, 2004 | 09:26 PM
blackws6's Avatar
Default ses light
is there any way to reset the ses light on a 98 ls1 without havin a garage doin it? its on b/c my passanger o2 sensor keeps freezing. any help would be appreciated.
Old Apr 25, 2004 | 10:04 PM
Z'mnypit's Avatar
Yeah, with the key in the ignition turn it forward, but dont start the car... Look under the hood & find the PCM ignition & the PCM battery fuses... Pull them.. keep in mind that the key is still on.. leave it on.... After you pull the fuses wait about 5 mins. then turn the key off replace the fuses.. then you should be good to go... Your pcm will relearn its self so dont worry about that.... Hope this helps. Good luck!!!!!
